Changing the Track Color on the eTrex 20/20x/22x/30/30x/32x
On the eTrex® 20, 20x, 22x, 30, 30x, and 32x outdoor handhelds you can change the color of individual tracks. You can also change the default track color that is used for all new tracks.
Changing the Color for All Tracks
From the main menu, select Setup.
Select Tracks.
Select Advanced Setup.
Select Color.
Select the desired color.
Now while on the Map page, the tracks will appear as the newly selected color.
Changing the Color of a Single Track
From the main menu, select Track Manager.
Select the Current Track or a saved track.
Additional Steps for Archived Tracks:
Select Archived Tracks.
Select the track you want to change.
Select Make Favorite.
Select the saved track.
Select Set Color.
Select Show on Map.
NOTE: If you only see Hide on Map, skip this step.
Now while on the Map page, the track will appear as the newly selected color.
