Devices Unable to Read Files Larger than 2GB in Size
NOTES:
The following devices cannot read or use any file that is larger than 2GB in size:
  • BMW nüvi® 350
  • BMW nüvi® 360
  • nüvi® 350
  • nüvi® 360
  • nüvi® 370
  • nüvi® 600
  • nüvi® 650
  • nüvi® 660
  • nüvi® 670
  • nüvi® 680
  • nüvi® 5000
Though these devices are compatible with SD cards larger than 2GB, any individual file on an SD card or the device's internal storage cannot exceed 2GB in size, or the file will not be seen by the device. This is most commonly a problem with European mapping but will occur with any 2GB file. The above device series are not compatible with the supplemental mapping of Europe for this reason.
For information on how to change installed regions of the maps, see the FAQ Reinstall or Change Map on an Automotive Device.
