Correcting Low Volume on a dēzl™ GPS Navigator
If you are having trouble hearing the sound coming from your device, ensure that the volume is set to an audible level. The overall volume can be adjusted by using the volume buttons on the back of the unit. Additional volume controls can be found in the device's settings.
To Check the Volume Level:
Open the device's Settings or the gear icon
In the Device section, touch Sound & notification
Confirm the desired volume for any that apply:
Navigation
Media
In-Call
Alarm
Notification
The volume should now be set to the desired level.
The View Map screen also has a Volume map tool. See your device's owner's manual for more info on enabling map tools.
To Adjust the Volume on the View Map screen:
Touch the wrench
or menu icon
Touch Volume
Adjust the slider to the desired level
