Charging the inReach Mini 2
NOTE: To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer. The device does not charge when it is outside the approved temperature range (0° to 45°C or 32° to 113°F).
Charging the inReach® Mini 2 Satellite Communicator
  1. Lift the weather cap figure one.
    One Weather Cap and Two Charging Port
  2. Plug the small end of the power cable into the charging port figure two on the device.
  3. Plug the other end of the power cable into a compatible AC power adapter.
  4. Plug the AC power adapter into a standard wall outlet.
  5. Charge the device completely.
NOTE: If your device is configured with Auto Track enabled, to avoid unwanted track points and any potential related charges you can disable the use of Auto Track or use the low power charging mode listed below.
Saving Energy While Charging the inReach Mini 2 Handheld
  1. Connect your device to an external power source.
  2. Hold the power button until the screen turns off.
    The device goes into a low power, battery charging mode, and the battery gauge appears.
  3. Charge the device completely.
See Low Power Charging Mode Icons for more information  Status Icons on the inReach Mini 2
