Wirelessly Charging Your Qi-compatible Garmin Device
Requirements Before You Begin:
A vívomove® Trend watch.
A Qi-certified charging pad that provides a flat and level charging surface. An example includes:
NOTE: Upright wireless charging stands (such as those intended for smartphones) or automotive wireless chargers (such as those built-in to vehicles) may not be compatible.
A list of Qi-certified chargers is provided by the Wireless Power Consortium (WPC): https://www.wirelesspowerconsortium.com/products
How to Wirelessly Charge Your Qi-Compatible Garmin Device
Connect your Qi-certified charging pad to a power source as instructed by the pad’s manufacturer.
Place the charging pad on a flat and level surface.
Before placing the Garmin device onto the charging pad, align the center of the Garmin device with the charging pad’s coil location as indicated on the pad.
If there is no indication of where the charging coil is, align the Garmin device with the center of the pad.
Place the bottom side of the Garmin device on top of the charging pad with the display facing up.
- The display on the Garmin device will indicate the charging status.
Troubleshooting:
If charging does not start:
Completely remove the Garmin device from the charging pad for at least 3 seconds.
Replace the Garmin device on the charging pad, ensuring it is properly aligned with the charging coil.
Some chargers may need to be reset if charging does not start:
Completely remove the Garmin device from the charging pad.
Unplug the charging pad from its power source for several seconds.
Reconnect the charging pad to its power source and wait until it turns on.
Some charging pads are sensitive to how the Garmin device is placed on them:
Ensure the Garmin device is aligned with the charging pad’s coil location while it is being placed on the charging pad.
Try placing the Garmin device slowly onto the charging pad to establish charging.
After placing the Garmin device onto the charging pad, try repositioning the Garmin device around the charging pad’s coil location to start charging before re-aligning the device with the charging pad’s coil location.
Some charging pads contain multiple coils:
Ensure the Garmin device is aligned with the primary coil as indicated by markings on the charging pad or by the manufacturer documentation.
If the first coil does not successfully charge the Garmin device, try each of the other coils.
Wireless charging speed may vary depending on the charger used and the surrounding environment
Avoid wirelessly charging in a hot environment or in direct sunlight.
Wireless charging operates best in 20~30°C (68~86°F) environments.
If your preferred charging pad is still unable to charge your Garmin device, it may be necessary to use a different Qi-certified charging pad.
