Getting Started With the Rino 700
Below is a list of articles that will help you get started with, and get the most out of, your new Rino® 700 outdoor radio and GPS.
How Do I Get Started?
First, we recommend that you fully charge your Rino handheld (see - Charging the Battery).
  1. Power on the Rino handheld by holding Power Button on the side.
    Learn More About the Touchscreen and Buttons
    Rino 700 Button Layout
    ONE CALL KEY
    Rino Call Key
    • Press to transmit an attention tone on the current channel.
    • Hold to send an emergency alert to all Rino users on the current channel and code (Emergency Alerts).
    TWO POWER KEY
    Power Button
    • Short press to adjust the backlight and check battery level.
    • Press and hold to turn the device on.
    • Press and hold until you see power icon to turn the device off.
    THREE MENU/ZOOM KEY
    Menu Key
    • Press to open the menu for a page or item.
    • Press twice to return to the main menu.
    • Press and hold to adjust the zoom level of the map.
    FOUR BACK KEY
    Back Arrow
    • Press to return to the previous item or menu.
    five instruction THUMB STICK™
    Rino 700 Thumb Stick
    • Move up/down or right/left to move through lists, highlighted fields, adjust sliders, or move the map panning cursor arrow.
    • Press in to select an item.
    • Press in and hold for two seconds to mark your current location as a waypoint (Waypoints).
    SIX VOLUME/SQUELCH KEY
    Speaker Symbol
    • Select to adjust the volume and squelch levels.
    SEVEN PTT (PUSH-TO-TALK)
    • Hold to transmit on the current radio channel (Transmitting).
  2. Select your language from the list.
Learn More About the Rino 700 Handheld
The following articles will help you explore and use the many features of the Rino 700 handheld.
Communication Features
Waypoints, Tracking, and Navigation
Battery and Charging Features
