Changing the Update Rate While on a Hunt
While on a hunt, it is possible to change the update rate of the Astro® dog tracking collars. The handheld will need to be no more than 10 feet away from the dog collar device to have the change take place. In contrast, the Alpha® dog tracking systems can change the update rate collar at the full range capability of the system.
Changing the Update Rate on the Alpha 200 or Alpha 300 Dog Tracking and Training Handheld
  1. Ensure the tracking collar is turned on and tracking
  2. Go to the Main Menu
  3. Select Dog List
  4. Select which Dog/Collar you would like to adjust
  5. Select Update Rate
Changing the Update Rate on the Alpha 10 Dog Tracking and Training Handheld
  2. Use the Thumb Stick to select which collar to change
  3. Press in on the Thumb Stick for Device Options.
  4. use the Thumb Stick to select Edit.
  5. Select Update Rate.
Changing the Update Rate on the Pro 550 Plus Dog Tracking and Training Handheld
  2. Set the Toggle Switch to the collar to change.
  3. Set the Dial to N.
  4. Press the Tone button.
  5. Press the training button to highlight Update Rate.
  6. Press the Tone button to select.
  7. Press the Training button to highlight the new update rate.
  8. Press the Tone button to select.
Changing the Update Rate on the Alpha 100 Dog Tracking Handheld
  3. Select Dog List
  5. Select Menu
  6. Select Change Update Rate
Changing the Update Rate on the Astro 430 Dog Tracking Handheld
  3. Select Dog List
  5. Select Show Info
  6. Select Menu
  7. Select Change Update Rate
Changing the Update Rate on the Astro 220 or Astro 320 Dog Tracking Handheld
  1. Ensure the tracking collar is on and has a connection
  3. Select Dog List
  4. Select which Dog you want to change the update rate for
  5. Select Show Info
  6. Select Menu
  7. Select Comm Settings
  8. Select an ID number
  9. Select Update Rate
The Astro 430, Alpha 100, and Alpha 200i handhelds can have the update rate set on the collars to Dynamic, 2.5 seconds, 5 seconds, 10 seconds, 30 seconds, or 2 minutes. The Astro 220 and 320 handhelds can have the update rate set to 5 seconds, 10 seconds, 30 seconds, or 2 minutes. Using a slower update rate of the DC™ collar can increase battery life, while using a faster update rate can decrease the delay between updates, which will provide more up-to-date information concerning the dog's actions.
NOTE: The dynamic tracking rate is only available on the Alpha T20 and TT 25 collars.
Related
