View, Share, and Delete Dash Cam Device Videos with the VIRB Mobile App on an iPhone
You can view, save, share, or delete dash cam videos and pictures taken from your device on your iPhone using the VIRB® Mobile App. The VIRB Mobile App is a free application that will allow you to easily save or share videos/pictures taken with your Garmin Dash Cam.
Note: iOS version 10.0 or later is required.
See the Dropdowns Below for Setup and Usage Steps:
Installing the VIRB Mobile App
See Installing the Garmin VIRB Mobile App.
Once you have the application downloaded and have some recorded video footage on your Dash Cam, you will need to set up a Wi-Fi connection between your camera and the app on your phone.
Setting Up the Connection on the Garmin Dash Cam
  1. Select Gallery from the main menu
  2. Select Share Gallery
  3. The Dash Cam will display the Network Name and Password
Setting Up the Connection on the iPhone
1. Open the Settings on your iPhone
2. Touch Wi-Fi
3. Enable Wi-Fi
  • Skip this step if already enabled
4. Select the Network Name displayed on the Garmin device
5. Enter the Network Password displayed on the Garmin device
It may take about a minute to display all videos once connected.
Viewing a Video or Photo
1. Launch the VIRB Mobile App
2. Select the desired video
3. Touch the play icon
Note: If there is no unsaved footage recorded, or if the unsaved footage has been deleted, the following message will appear when touching Unsaved Footage in the VIRB Mobile App.
Sharing or Downloading a Video or Photo
1. Select the desired video in the VIRB Mobile App
2. Touch the Share icon (box with an up arrow)
3. Trim the video as desired by touching and dragging the brackets on either side of the timeline at the bottom of the screen
    • Note: Trimming the video will not delete the original video
4. Touch Next
5. Touch the Upload/Share button (box with an up arrow coming out of it)
  • Touch the Download button (box with a down arrow going into it) to save the video/photo to the phone's gallery instead
6. Select the desired sharing method
You will have sharing options such as text, e-mail, Facebook, YouTube, and more. The options found here will depend on the apps installed on your phone.
You can delete any selected video by pressing the trash can icon on the main screen of the VIRB Mobile App.
See SD Memory Card Sizes for Automotive Devices to ensure you are using a compatible microSD card for recording video.
