File Limitations of the Alpha 200 and Alpha 200i
When sending or creating files for an outdoor device, keep in mind the following device limitations:
Alpha® 200 or Alpha® 200i Dog Tracking Handhelds
2,000 GPX files
10,000 waypoints
No limit on geocaches (outside of max number of GPX files supported and memory available)
250 routes, 250 points per route; 50 points turn-by-turn routing
250 saved tracks
2,000 archive tracks
20,000 points per track
100 custom map tiles
250 BirdsEye imagery files
Limit is combined total of BirdsEye imagery files downloaded using BaseCamp™ software and/or BirdsEye Direct files downloaded using the device.
Mapping segments 15,0001
Each 24k Topo product can contain roughly 3000 segments or more.
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 See Related for more information on map segments.
