Navionics Boating: Accessing Track Information
Once a track has been saved, you can access it from Menu > Tracks. From here, select the track you wish to see data for. Once you do this, you will see the yellow track line on your map shown in a minimized version at the top of the screen, as well as stats for that track such as max speed, time, and distance.
With Android devices, you can tap the chart image to view the track line full screen on the map.
For Apple devices, tap the map at the top of the track screen to view the track in playback mode. Exit all the way back to the map screen (tap the < Back and X buttons in the upper-left until you get back to the chart) to view the track line full screen.
