Garmin BlueChart Mobile Chart Not Rendering After iOS 13 Update
With the release of iOS v13.00, the chart rendering detail in BlueChart Mobile is corrupted when zoomed in over 2 nautical miles (see example below). BlueChart Mobile has been discontinued and is no longer supported.
As an alternative, we recommend using either the ActiveCaptain application, or the Navionics application.
If you own a Garmin chartplotter, we recommend the use of the ActiveCaptain application which is designed to be used with a Garmin chartplotter. More information about the ActiveCaptain application can be found here.
If you do not own a Garmin chartplotter, we recommend the use of the Navionics application. More information about the Navionics application can be found here.
BlueChart Mobile charts will not be supported on the Navionics, or any other, application.
BlueChart Mobile Chart Rendering
For instructions for saving and transferring BlueChart Mobile data, please see Related Content below.
Related
