The NEO 2 comes with all the parts and accessories needed to set up most bikes and begin indoor cycling training. This FAQ will explain what parts are included in a NEO 2.
What’s in the Box?
NEO 2 trainer
Wheel block
Power Cord
NEO 2 Fitting Kit
130 mm non-drive side quick release adapter (preinstalled on trainer)
Quick release drive side adapter (preinstalled on trainer)
Type 2 Shimano/SRAM cassette body (preinstalled on the trainer)
Rubber cap set- installed on trainer
What Is Included in the Neo 2 Fitting Kit?
A. Tacx Universal quick release skewer B. 2.7 mm non-drive side spacer Used for bikes with wider dropouts preventing proper bike installation on the trainer or for bikes with a disc brake that rub on the trainer. C. 0.5 mm cassette hub spacer Used if derailleur is touching trainer while in lowest gear. Installed on the axle behind the cassette body D. 1 mm cassette hub spacer Used when derailleur is touching trainer while in lowest gear. Installed on the axle behind the cassette body E. Cassette spacer Used when installing 8-10 speed cassettes on included cassette body. Installed behind the bike's cassette
Replacement Part Numbers
Part Description | Part # |
Wheel Block North American Power Cord Power Adapter NEO 2 Fitting Kit Tacx Universal Quick Release skewer Type 2 Shimano/SRAM cassette body Rubber cap set | S2850.05 S1961.60 S2800.04 S2800.01 T1402 S0050 S2800.05 |
