Locating GSA 28 Servo Serial Numbers
Locate and record the serial numbers for each GSA 28 servo installed in the aircraft by following the instructions below.
- Power up Master and Avionics Master switches.
- G3X Touch™ avionics(Software version 9.15 and above)
- Power on the Display.
- Press the "Menu" button.
- Press the "Menu" button a second time.
- Press the "Tools" button.
- Press the "Diagnostic" button.
- Press the "System" button.
- Scroll to Roll/Pitch/Pitch Trim.
- G5
- Press and hold the knob, while powering on.
- Press the "Device Info" button.
- Power off the device.
- GI-275
- Press and hold the knob until the Menu Appears.
- Scroll Right and press the "System" button.
- Scroll Right and press the "External LRUs" button.
- Scroll down to Roll/Pitch/Pitch Trim.
- G500/600 and G500/600 TXi™ displays
- Access the GSA 28 Serial number through a G5, or a GI-275 as described above.
- Note the serial number(s) of the GSA 28 devices in the aircraft.
- Select the "Serial Number Lists" link below to cross reference the GSA 28 serial numbers from the aircraft.
