Factory resetting a VHF 100/110/200/210 radio
If necessary, you can restore the radio to its factory default settings. Please be advised that when you perform this action, any changes you have made to the radio settings will be lost and the call logs will be deleted. Group entries, the directory, the MMSI number and the ATIS  ID will be retained.
To reset the radio please follow these steps:
  1. Press the MENU key.
  2. Select SYSTEM>SYSTEM  INFO.
  3. Select RESET.
  4. Select YES.
The VHF radio will now be restored to factory default settings.
