Installing Vector 2 Pedal Pods
Vector 2/2S pedal pods can be installed and removed independently of Vector1 pedals. Please wipe the pedal spindle between the pedal and the crank arm clean before install. After ensuring the installation area is free of any grease or debris, please use the following steps to install.
  1. Wrap pedal pod around pedal spindle.
  2. Insert pedal pod connector into spindle.
  3. Insert hex screw into pedal pod.
  4. Tighten using tool provided until screw is snug, but not tight2.
Following these steps will help to ensure accurate, reliable readings from your Vector 2/2S power meter.
1Original Vector and Vector S pedals will need the respective Vector 2 Upgrade kit.
2We recommend using a 2.5 mm hex key for install. Avoid over-tightening as this could damage your pedal pod.
