Race Timer on the Garmin Catalyst
The Race Timer will keep track of your lap number and show your best lap times. See below for a breakdown of the information.
- Last Lap: Displays the last lap time during the current session
- Best Lap: Displays the best lap time for the current session
- Delta: Displays the time difference between the current lap and the best lap during the current session
- End: Select to end the current session
- Lap: Displays the current lap number
- Total Time: Displays the total lap time
You can adjust the Delta Timer to compare the difference in time between your current lap and your personal best, session best, today's best, or optimal lap. You can also choose whether to display or hear lap times.
See the detailed video or steps below for instructions.
To Adjust the Delta Timer
- Touch Lap Timer when setting up a Drive Session
- Touch Delta Timer
- Select a Delta Timer option
- You can choose Session Best, Today's Best, Personal Best, or Optimal
To Adjust the Lap Timer Options
- Touch Lap Timer Display
- Select a Lap Timer Display option
- You can choose Show During Race or Hide During Race
- Touch Audible Lap Times to turn them on or off.
The Delta color band is designed to allow you to see the color and intensity change in your peripheral vision without taking your eyes off the track.
- See green on the screen if you're beating your best lap time
- See red if you're lagging behind
