Can I Make or Take Phone Calls on My Garmin Watch?
Yes, many Garmin® watches allow you to interact with phone calls, but the features available depend on your watch model. The key factors are whether your watch has a built-in speaker and microphone or an active LTE subscription.
This guide explains how to use your watch for phone calls based on its hardware.
Topics
Watches Without a Speaker and Microphone
If your watch does not have a speaker or microphone, you can still manage incoming calls from your wrist.
  • View Notifications: When your paired smartphone receives a call, the watch will display the caller's name or number.
  • Accept or Decline Calls: You can select the accept or decline icon on the watch. This action controls the call on your smartphone. For example, accepting the call on the watch will answer it on your phone, and you will need to use your phone to talk.
  • No Outgoing Calls: You cannot place a call from a watch without a speaker and microphone.
Back to topics
Watches With a Speaker and Microphone
Garmin watches that include the voice assistance feature come with a built-in speaker and microphone that allows you to make and take calls directly on the watch while connected to your smartphone via Bluetooth® and the Garmin Connect™ app. For more information about this feature see: Setting Up Voice Assistant on Your Garmin Watch
When you answer an incoming call on the watch, the call audio will automatically be routed through the watch's speaker and microphone. If you are using a third-party app (like WhatsApp, Messenger, etc.), you may need to manually transfer the call audio to your watch from your phone's call screen. This process will vary by phone manufacturer.
Making a Call From a Voice Assistant Watch
Watch models compatible with this feature are listed below.  Choose a model to reveal instructions on how to make a call while paired to your phone via Blutooth.
D2™ Air X10 | Venu® 2 Plus
  1. Hold the Letter B in a Circlebutton (bottom right).
  2. Select Phone Calling.
  3. Select an option:
    • Select 9 circles to represent a keypad to dial a phone number.
      • Select Phone inside of a green circle to make the call.
    • Select Book icon with person ouline to access your Contact list.
    • Select Arrow pointing upward to view recent calls made or received on the watch.
      • Selecting one will dial that person from the watch.
Venu® 3 | Venu® 3S
  1. Press theCapital letter A in a circle button (top right).
  2. Select Apps.
  3. Select Phone.
  4. Select an option:
D2™ Air X15 | D2™ Mach 2 | fēnix® 8 Series | Forerunner® 570 | Forerunner® 970 | quatix® 8 | tactix® 8 Series | Venu® 4 | Venu® X1
  1. Press the Watch with circle on top right corner top right button.
  2. Select Phone.
    • Press the Watch with circle on middle left side middle left button or swipe up to view the dial pad.
      • Select Voice Call Start to make the call.
    • Select Contacts to access your contact list.
Back to topics
Watches With LTE Connectivity
In addition to the features listed above, these models feature LTE Connectivity allowing you to make and receive calls when you have an active LTE subscription.
Compatible Watches
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED
For details on how to make and receive voice calls see: Calling and Messaging Using the fēnix 8 Pro.
Back to topics
Phone Call Controls
NOTE: Available options may vary by device. See your owner's manual for more information.
Incoming Calls
On watches with a speaker and mic, answering takes the call on the watch. Otherwise, these actions control the call on your paired phone.
  • Green phone icon inside of a half circle Accept: Answers the incoming call.
  • Red phone icon inside of a half circle. Decline: Declines the incoming call.
  • Message bubble icon inside a green circle Decline and Reply: Declines the call and sends a text message reply (Android only).
Controls During a Call
Some devices may require you to tap Arrow pointed downto view additional call controls.
  • Red phone icon in a red semicircle End Call: to end a call.
  • Watch icon with arrow pointing inwards To Watch: Transfers the active call from your phone to your watch.
  • Phone outline with an arrow pointed inward To Phone: Transfers the active call from your watch to your phone.
  • Microphone icon inside of a circle Mute Mic: Toggles the watch microphone on or off.
  • Plus sign inside of a circle. Add Call: Adds another person to the call.
  • Mute Audio icon inside of a white circle Mute Speaker: Toggles the watch speaker on and off.
  • 9 dots to represent a keypad Keypad: Opens the number keypad.
Related
