Disabling Driver Assistance Alerts on a Garmin Dash Cam
Your Garmin Dash Cam™ driving recorder has built-in Driver Assistance Alerts which include Forward Collision, Go Alert, Lane Departure, and Proximity Alerts/Garmin Red Light Cameras. These alerts can be enabled and disabled at any time.
To Enable/Disable Driver Assistance Alerts on Your Dash Cam:
1. With the  down button go to Settings, then press the select  button.
    • Swipe the touchscreen on the Garmin Dash Cam™ X310, then select Settings.
2. In Settings, select Driver Assistance
3. In Driver Assistance:
    • Select Forward Collision to change the sensitivity or turn the alert Off.
    • Select Go Alert to check (enable) or uncheck (disable).
    • Select Lane Departure  to check (enable) or uncheck (disable).
    • Select Proximity Alert (or select Garmin Red Light Cameras on the Garmin Dash Cam™ X110, Garmin Dash Cam™ X210, Garmin Dash Cam™ X310).
      • Select Audio to change to Single Tone, Continuous Tone or Off to disable Proximity Alerts
      • Select Alerts to disable Garmin Red Light Cameras
Back out of settings to save the change(s).
NOTE: When disabling Forward Collision, Go Alert, Lane Departure, and Proximity Alerts/Garmin Red Light Cameras, both the audible and the visual alert will be disabled. The Proximity Alert is the only alert capable of disabling the audio only while still getting the visual proximity alert.
  • Proximity Alert Settings:
    • Audio (On/Off Audio)
      • Single Tone
      • Continuous Tone
      • Off
    • Alerts (On/Off Audio and Visual)
      • Garmin Red Light Cameras
Driver Assistance Alert Descriptions:
Forward Collision Warning
The Forward Collision Warning System (FCWS) feature allows the device to detect when you are not maintaining a safe distance between your vehicle and the vehicle in front of you. The device will estimate your vehicle's speed using GPS, then calculate an estimated safe following distance based on your speed. The FCWS activates automatically when your vehicle speed exceeds 30 miles per hour (48 km per hour).
Go Alert
The Go Alert plays a tone and displays an alert when stopped traffic ahead of your vehicle starts moving again. This alert appears only after the vehicle ahead has moved a substantial distance and your vehicle has remained stopped. This can be useful at stop lights or in traffic delays. This feature uses the dash camera to detect the stopped or moving vehicle and requires a clear view of the road.
Lane Departure Warning
The Lane Departure Warning System (LDWS) feature alerts you when the device detects you may be crossing a lane boundary unintentionally. For example, the device alerts you if you cross some solid painted lane boundaries or cross into an oncoming traffic lane. The LDWS feature provides alerts only when your vehicle speed exceeds 40 miles per hour (64 km per hour). The alert appears on the left or right side of the screen to indicate which lane boundary you crossed.
Proximity Alerts
Red Light and Speed Cameras
Red Light and Speed Camera alerts (sold separately) will allow your device to alert you to upcoming speed and red light cameras. Coverage is not available in all areas.
The device plays a tone and displays the distance to the red light camera.
The Garmin Dash Cam X110, X210, X310, Garmin Dash Cam 45, 46, 55, 56, 65W and 66W driving recorders come pre-loaded with a trial of the camera service covering its home region, e.g. North American versions of the Dash Cam 45 will come with a trial of the US & Canada service.
The Garmin Dash Cam Live, and Garmin Dash Cam 47, 57, 67W driving recorders come pre-loaded with subscription-free updates via the Garmin Drive app or Garmin Express.
A Red Light and Speed Camera subscription will need to be purchased for updated camera locations or camera coverage in additional countries. See Purchasing and Installing a Red Light and Speed Camera Subscription.
