Managing Multiple Camera Feeds on the BC 30 Wireless Backup Camera
You can pair up to four BC™ 30 wireless backup cameras with the BC 30 receiver cable. For example, one camera can be mounted on the back of your vehicle and a second camera on the back of your trailer.
You can cycle through video feeds from all paired cameras in the camera view of the automotive device to which your BC 30 transmitter is paired. For steps to pair a secondary camera to your transmitter, see Pairing the BC 30 Wireless Backup Camera Transmitter and the BC 30 Receiver.
If the transmitter and receiver cable are properly installed, but you are unable to view any video from your primary and/or secondary cameras, manually pair the transmitter and receiver cable again.
See the detailed video tutorial for pairing instructions:
To Cycle Between Camera Feeds:
  1. Open the camera view of your automotive device.
  2. Touch the  Change Camera icon. The video feed from the next camera will appear, with the name of the camera at the top of the screen.
  3. After adding a secondary camera to your transmitter, you can use your paired automotive device to rename the cameras, change the order in which they appear, or remove them.
To Rename a Camera Feed:
  1. Touch Settings
  2. Touch Backup Camera or Wireless Camera
  3. Select the camera
  4. Touch the  menu icon
    • Skip this step on some devices
  5. Touch Rename
The camera feed will now be renamed.
To Change the Order in which the Camera Feeds are Displayed:
  1. Touch Settings
  4. Touch Set Default Camera
  5. Drag each camera into the correct order.
The camera display order will now be changed. The camera at the top of the list will be considered the default camera and will appear first whenever the camera view is selected.
To Remove a Camera Feed:
  1. Touch Settings
  5. Touch Unpair
  6. Touch Yes (on some devices)
The camera feed will now be removed.
