Garmin Catalyst Cables
The Garmin Catalyst comes with four different cables included in the box.
  • Short cable = microUSB Computer connection cable
    • Use the micro USB end to connect to the side port on the device and the USB end to connect to a computer
    • This provides the connection needed if you want to update with Garmin Express
    • The device can be updated with Wi-Fi
    • Measures 1.5 feet / .5 meters
  • Medium cable = Garmin Catalyst power cable
    • Use the mini USB end to connect to the magnetic mount and the USB end to connect to the 12-volt Socket Power Adapter plug
    • This provides power to the Garmin Catalyst
    • Measures 5 feet / 1.5 meters
  • Long cable = Remote Cam power cable
    • Use the micro USB end to connect to the Remote Cam and the USB end to connect to the magnetic mount
    • This provides power to the Remote Cam
    • Measures 11.5 feet / 3.5 meters
  • Bare Wire Power Cable = Alternate Garmin Catalyst power cable
    • Use this cable if you prefer to hardwire your device
    • The cable powers your device and is compatible with 12V and 24V systems
    • Measures 18 feet / 5.5 meters
Related
