Connecting a Bluetooth Headset to a Rino 750, 750t, or 755t
Rino® 750, Rino® 750t, and Rino® 755t outdoor handhelds have built-in Bluetooth connectivity for features such as notifications, activity uploads to Garmin Connect™ account, software updates, geocache downloads, and weather information. It also allows these Rino handhelds to be paired with a Bluetooth headset.
When paired to a Bluetooth headset, incoming transmissions will be heard directly through the headset. However, outgoing transmissions cannot be made through the headset and must be sent using the Rino handheld's internal microphone. This limitation applies regardless of whether the unit is set to operate on VOX (Voice Operated Transmission), or PTT1 (Push-To-Talk).
Pairing to a Bluetooth Headset
Place your headset into pairing mode before following the steps below. Refer to the headset manual or manufacturer for assistance, if needed.
  1. From the app drawer on the Rino, select Setup.
  2. Select Bluetooth.
    • If not already in enabled, select Bluetooth to enable.
  3. Select Audio Device.
  4. Select Add Device.
  5. Follow the on-screen prompts to complete the pairing.
Additional Information and Troubleshooting
Is My Specific Model Headset Compatible?
Your Rino has been designed to support standard Bluetooth 4.0 protocols for wireless audio playback. However, there are many Bluetooth headsets to choose from, and as a result, there are differences in performance between headset models and manufacturers. With so many options, a list of every headset that may or may not work with your Rino handheld would be far too extensive. The easiest way to find out if it will work, is to pair and test it.
NOTE: Not all headset features will work with your Rino handheld.
I Am Having Audio Cut Out Issues with My Bluetooth Headset. What Can I Do?
If you are experiencing audio cut out or the headset disconnects while you use your Rino handheld, this could be due to the following:
Distance Between the Rino Handheld and Headset
  • The location of the Bluetooth receiver will vary across brands and models of headsets, in either or both earbuds or in the control module, for example. Holding the Rino in the opposite hand may help improve the connection.
Being Indoors vs. Outdoors
  • When you are indoors, there are walls for the Bluetooth signal to bounce from between the Rino handheld and headset, so reception may be better than outdoors.
Body Interference
  • With some models, it may be possible to wear the headset in a way that the Bluetooth receiver is not snug against your head. In general, not having the receiver tight against your head or body will improve Bluetooth reception.
Out of Date Software
  • Confirm that your Bluetooth headset is running the latest available system software. Consult your headset manufacturer for assistance if needed.
  • Confirm the Rino handheld is on the latest version of software by connecting it to a computer and using  the Garmin Express™ program: Installing Software Updates to Outdoor/Marine Handhelds
Additional Factors
  • Ensure your headset is not also paired to another device that is in range as this may cause issues.
  • Headsets which have a low battery could cause the connection to drop.
  • Some headsets have better receivers than others, and those with more sensitive receivers will work best with your Rino.
When Paired to My Bluetooth Headset, I Cannot Hear Others or Others Cannot Hear Me. What Can I Do?
If others in your party cannot hear your outgoing transmissions, or you cannot hear theirs, it may be due to the items above or the following:
Volume
Correct Channel and Code
Line-of-Sight
  • Ensure you are in line-of-sight range with the other individuals in your party. Maximum range is up to 20 miles over GMRS (US); up to 13 km over GMRS (Canada).
1The only exception to this are 3M Peltor WS Bluetooth headsets which allow PTT transmissions to be sent through the headset itself. This functionality is not a supported feature.
