My Watch Face and Brightness Settings Disappeared on My Garmin Watch
If you unexpectedly notice your Garmin® watch with a different watch face and a low brightness setting (example image below), you have most likely entered into the battery saver mode. The Battery Saver feature on select models, when enabled, changes the behavior of the watch and disables specific functionality to prolong the time between charges. You are not able to customize features disabled by Battery Saver mode while Battery Saver is enabled.
Watch Face when Watch has entered Battery Saver Mode
How to Disable Battery Saver Mode:
These steps may vary between models. For exact steps, refer to your owner's manual.
  1. Access the Settings menu on your watch.
  2. Select System.
  3. Select Battery Manager/Power Manager.
  4. Disable Battery Saver (toggle should be gray).
    Battery Saver Off Toggle Switch
Once confirmed, return to your watch face and it should be back to your previous watch face and brightness settings.
Garmin Watches With a Battery Saver Mode:
  • D2™ Air | D2™ Air X10
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar  - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 | Descent™ Mk3i | Descent™ Mk3i
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® - Tactical Edition | Instinct® - Esports Edition
  • Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition |  Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® E
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq 2 | Venu® Sq 2 - Music Edition
  • Venu® X1
  • vívoactive® 5
  • vívoactive® 6
Related
