Depth, water temperature, and water speed metrics not appearing on the navigation chart of a GPSMAP 4xx or 5xx series chartplotter/sounder
The numbers will appear on the map page once the Data Bar has been turned on. These numbers are only available for a sounder model device (i.e. GPSMAP 547s) that have a transducer directly connected to the device. If a non-sounder model (i.e. GPSMAP 547) is being used, this information will need to be sent to the device over NMEA 0183 or NMEA 2000.
To display these numbers in a Data Bar on the Gray Series:
- Press the Home button
- Choose Charts
- Select Navigation Chart
- Press the Menu button
- Choose Data Bars
- Choose Fishing
- Select "On" to enable the Fishing Data Bar
To display these numbers in an Overlay Number on the Black Series:
- Choose Charts
- Select Chart Setup
- Select Overlay Numbers
- Choose Edit Layout
- Use the Arrow Pad to highlight and select the data field to change
- Select the category of data that you want to view
- Using the + or - buttons will change the Layout
