Open the Garmin Connect app.
Select More (bottom right).
Select Health Stats or Health & Performance.
Select Weight.
Top FAQs for Weight Data In Garmin Connect
Select a topic below to view details on frequently asked questions about weight data in your Garmin Connect™ account.
How Do I View My Weight Data In Garmin Connect?
Weight data can be viewed in your Garmin Connect account after an upload from a Garmin Index™ Smart Scale or after manually entering a weigh-in . MyFitnessPal can also send weight data to your Garmin Connect account if you have the accounts linked (see: Steps to Link Your Garmin Connect Account with MyFitnessPal).
NOTE: Body composition data can only be uploaded from a Garmin Index Smart Scale.
Viewing Your Weight Data on the Home Page
You can add the Weight card to your Home page to be seen in the At A Glance section. This card will show your last weigh-in, which you can select to show a more detailed view. For steps to edit the At A Glance menu, see: Editing the Home View in the Garmin Connect App
Viewing Your Weight Data on the Weight Details Page
You can access the Weight page from the Health Stats page. Select an option below to see steps:
From a web browser, sign into your Garmin Connect account.
Select Health Stats from the navigation bar on the left.
Select Weight.
How Do I Manually Enter My Weight into Garmin Connect?
Your Garmin Connect account allows you to upload your body composition from a Garmin Index Smart Scale. You can also manually enter in your weight; however, any other body composition data must be uploaded using the scale itself. Select your platform below to reveal instructions to manually enter your weight into Garmin Connect.
How Do I Create or Edit a Weight Goal in Garmin Connect?
Your Garmin Connect account can be used to set weight loss or weight gain goals. When you have a weight goal set, you can compare your last weight to your current goal on the weight graph of Garmin Connect. Select the platform below to get directions on how to set up or modify a weight goal in Garmin Connect.
Select Health Stats.
Select Weight.
Select
in the top right.
Select Edit Weight Goal.
Enter your desired weight goal.
Select Save.
Select Weight.
Select Weight Goal.
Select Save.
How Do I Delete A Weigh-In?
For steps to delete a weigh-in, please see: How Do I Delete Data From Garmin Connect?
Manually Updating Body Composition Data in the Garmin Connect App
Input your precise body fat percentage and skeletal muscle mass from a reputable analysis into Garmin Connect. This calibrates your Index S2 scale, using your data as a reference for more accurate future measurements.
See: Manually Updating Your Body Composition In Garmin Connect for steps to enter a manual reading.
Why Are There Extra Weigh-Ins on My Garmin Connect Account?
Your Garmin Connect account now supports multiple weigh-ins per day, allowing users to track their weight more than once per day. Weigh-ins can come from multiple sources, which means any of the following items can prompt a new weight entry to show up on your account:
NOTE: If you stand on the Garmin Index Smart Scale for longer than 20 seconds, you may see more than one weigh-in recorded on your account. This is because the scale starts to weigh you again after you've been on the scale for 20 seconds. The subsequent weigh-in may only contain weight and no body metrics due to the weigh-in not being completed. You can delete any unwanted weigh-ins recorded this way by clicking the 'trash' icon next to the weight entry.
Weigh-ins from a Garmin Index Smart Scale.
Syncing a device that has been paired with a Tanita scale.
Manual weight entries.
Weights synced from MyFitnessPal.
User profile updates.
Adding a new device to your account (if user profile and weight settings are part of the initial device setup).
Why Is the Time of My Weigh-In Incorrect?
Prior to May 2019, weights were recorded without a timestamp. This is true for measured weights from the Garmin Index Smart Scale and Garmin Index S2 Smart Scale. As well as manual weight entries and weights synced from MyFitnessPal, or other user profile updates.
If weight is recorded without a timestamp, they may show with an arbitrary time (e.g. 12AM/6PM) in order to show that they occurred on that particular day.
