Pairing a Pro Control G3 to PRO Control 2 Remote Release
A Tri-Tronics® Pro Control® G3® handheld can be paired to a Garmin PRO Control 2 Receiver. It is is important to keep in mind that due to the programming differences between the two devices only the Duck call tone, or first wav file, will work on the PRO Control 2 Remote Release when using the Pro Control G3 handheld.
To pair a Tri-Tronics Pro Control G3 and Garmin PRO Control 2 Receiver:
  1. Fully charge the PRO Control 2 Remote Release
  2. Select the transmitter dial number that you want to use when you operate the remote release
  3. With the receiver turned off, hold the power key for 3 to 5 seconds until the LED on the receiver is solid green and changes to solid blue
  4. While the LED on the receiver is blue, select the L, R or Tone on the handheld
  5. Select Tone to verify that the device is paired
The Pro Control G3 handheld and PRO Control 2 Remote Release should now be communicating.
