Automotive Devices that Display Points of Interest Icons on the Map
Some automotive devices will only display icons on the map for your saved Favorites. Preloaded Points of Interest (POIs) such as restaurants, hotels, attractions, etc. will not be displayed on the map unless they have also been saved as favorites.
The device will show the POI icons on the map when it has started moving or is in an active route.
POI icons will NOT display on the map if your map view is set to either North Up or Track Up.
