(2023) Service Advisory 23102 Rev B: Heavyweight Aircraft
REVISION B:
Added Resolution
PRODUCTS AFFECTED:
Textron Aviation Inc. (Beechcraft) King Air models B300 and B300C Heavyweight aircraft equipped with G1000 NXi Integrated Flight Deck installed per STC SA01535WI-D MDL Revision 22 and later FAA-approved revisions are affected.
ISSUE:
AFMS 190-00716-N8 Revisions 1 and later correctly identify the B300 and B300C Heavyweight aircraft as included in the STC RVSM (Reduced Vertical Separation Minimum) group approval.
ACTION:
It is now acceptable to operate in RVSM airspace if Takeoff Weight is greater than 15,000 lb.
RESOLUTION:
Garmin has updated STC SA01535WI-D to include the B300 and B300C Heavyweight aircraft in the STC RVSM (Reduced Vertical Separation Minimum) group approval. No change to the AFMS is required.
