Adding or Deleting a Bluetooth Pairing with a Scala Rider Q2 Headset and an Automotive GPS Navigator
To pair a Scala Rider Q2 with your Garmin device, follow the steps below. Before attempting the instructions, delete any Bluetooth headset pairings from your mobile phone and device. Consult the phone's owner's manual for instructions to clear the Bluetooth pairings from the phone.
To Delete the Bluetooth Pairings From the Device:
- Touch Settings
- Touch Bluetooth, Wireless Networks, or Headset
- Select the headset
- Touch Unpair device or Forget Device
- Touch Yes
The Bluetooth pairings will now be removed.
Setting the Scala Rider Q2 to discoverable mode:
Put the Scala Rider Q2 headset into discoverable mode by turning on the headset. Press and hold the Control button until the headset flashes red and blue.
Using the Device to Search for your Scala Rider Q2:
- Touch Settings
- Touch Scan for Devices, Search for Devices, Add Headset, or the
headset icon
- Touch OK
- If prompted to enter a passkey after the device finds the Q2, enter "0000"
You have now successfully paired the Q2 to your device.
Issues with Bluetooth can often be resolved by ensuring that the device has the latest device and Bluetooth software, using the Garmin Express™ application. See How Do I Install Garmin Express™?.
Note: If the headset and device will not pair or if they keep disconnecting, the headset may not be compatible with the device. Currently, the headset should be compatible if it supports the hands-free profile and has a Bluetooth version of 1.1 or higher, although it cannot be guaranteed.
