Setting Up the Radio on a Rino 520HCx and 530HCx
When setting up the radio on a Rino® 520HCx or Rino® 530HCx outdoor handheld select a channel and code to transmit on. Channels 1-7 and 15-22 are GMRS*, channels 8-14 are for FRS. Be sure to tell the other members of your group what channel and code you are using so they can communicate with you.
To Select a Channel:
- Highlight the Channel field and press Enter.
- Select an available channel and press Enter to accept the selection.
To Select a Code:
- Select the Code field and press Enter.
- Select one of the thirty-eight (38) available codes. Press Enter to accept the selection.
NOTE: Using GMRS channels requires an FCC license. See the Owner’s Manual for details.
