Using the "Where I've Been" App
"Where I've Been" is an app on your device that allows you to view a record of the device's travel history. It will display your routes on the map, as well as places you've stopped.1 "Where I've Been" will display only up to the last ten hours driven.
To Access the "Where I've Been" App:
  1. Touch Apps Drawer button
  2. Touch Navigation
  3. Touch "Where I've Been"
A box on the right-hand side of the screen breaks down the travel history by day. Tap it to expand it and scroll through the recorded days. Touch a specific date to view that day's travel history. If a day is grayed-out, then the device was not used that day or no travel history was recorded on that date. If the device was used on a day that is grayed-out, the travel history can be viewed in Garmin BaseCamp™.
To Disable Travel History:
  1. Touch Settings
  2. Touch Navigation
  3. Touch Route Preferences
  4. Touch Travel History to disable this function
  5. Touch Yes to confirm
    • Touch Clear Travel History to clear the history at any time
The travel history will now be disabled.
To Clear the Travel History Using the Apps Menu:
  1. Touch App Drawer button
  2. Touch Navigation
  4. Touch the menu button (three horizontal lines)
  5. Touch Clear Travel History
  6. Touch Yes to confirm
The travel history will now be cleared.
"Where I've Been" will only display locations you've stopped at for 15 minutes or longer. If you stop at a location for fewer than 15 minutes, it will not be displayed on the "Where I've Been" app.
