Instructions to Sync Deezer Music to a Compatible Forerunner
This article will provide the following steps to use the Deezer Connect IQ app on your compatible Forerunner watch.
Requirements to Use the Deezer Connect IQ App
The following are requirements to use the Deezer Connect IQ app on your watch:
What Forerunners Are Compatible with Deezer?
  • Forerunner® 165 Music
  • Forerunner® 245 Music
  • Forerunner® 255 Music
  • Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 645 Music
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
I Meet the Requirements. What's Next?
Follow each step listed below when first setting up the Deezer Music app with your Forerunner. Select each section to expand and view instructions on completing each step.
NOTE: You will only need to work through Step 3 from the list below if you are wanting to load additional content to your watch.
Watch this video first to see the process in action - Support: Setting Up Deezer on a Garmin Watch
Step 1: Download and Install the Deezer Connect IQ App
  1. Select the following link to download the app: Deezer Connect IQ App.
  2. Select down arrow next to download in a blue box button.
  3. If prompted, sign in to your Garmin account.
  4. Select your device to download the app.
  5. Acknowledge any app permission requests.
  6. Sync your device.
    • To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the key to access the Controls Menu. Select Two blue arrows circling each other to sync
    • To sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the key to access the Controls Menu. Select Two blue arrows circling each other to sync
    • To sync using Garmin Express: Connect the device to your computer using the supplied power/data cable and open Garmin Express. A sync will automatically occur once the device is detected.
The Deezer app will now be installed on your device.
Step 2: Set Up the Deezer Connect IQ App
NOTE: The watch must be able to connect to a previously connected Wi-Fi network. You will also need your smartphone that is paired to your watch. If you have not yet added a Wi-Fi Network to your Garmin Connect app please see: Setting Up or Troubleshooting a Wi-Fi Connection on a Fitness Device.
  1. On the watch, press and hold the DOWN key (the music shortcut key).
  2. Press and hold the UP key to access settings.
  3. Select Music Providers.
  4. Select Deezer.
    • The watch will search and connect to Wi-Fi.
  5. Once connected, the watch will display a message to open the Garmin Connect app to sign in. At the same time, your smartphone should display a similar notification.
  6. Acknowledge message on the phone which will take you to Deezer. Depending on whether you have an account, the login process will be as follows:
    • Existing Deezer Users: Enter your login details and select Log In.
    • New to Deezer: Select the Register here option and follow the steps to create your account.
  7. If prompted, enter credit card details to complete the process.
Step 3: Syncing Deezer Music to the Forerunner
NOTE: From your Deezer account, create playlists. Saved playlists will display as optional music to sync on your Forerunner 645 Music. For more information see Deezer Support
  4. Select Deezer.
  5. Select Add Music and Podcasts.
  6. Select My Playlists.
  7. Choose playlists you want to sync to your watch.
  8. Select Done.
  9. Press the Back button and select Yes to "Start music sync now?".
