Changing Your Current Location on a Touchscreen Handheld
If you would like your touchscreen handheld to show a different location other than your current location, the device can be put into demo mode. At that point, you can change the location. If the device is in Normal mode, it will automatically locate its correct position.
Remember to take the device out of demo mode when you are ready to use it again. Instructions for both enabling and disabling demo mode can be found below.
Changing the Current Location
Select your device below and follow the instructions
Alpha Series
- Starting at the Main Menu, touch
at the bottom of the screen
- Select Satellite
- Touch
- Select Use With GPS Off
- Touch
- Select Set Location On Map
- Use the Map to select the desired position
- Once the position is set, select Use
The new location will now be set as your current location on the device.
To quickly have the device locate your current location, turn the device off and back on. Alternatively, follow steps 1 through 3 from above and select Use With GPS On to locate your current location.
Dakota Series
- Starting at the Main Menu, select Setup
- Select System
- Select GPS
- Select Demo Mode
- Return to the Main Menu
- Touch
- Touch the bottom right corner of the screen
To quickly have the device locate your current location, turn the device off and back on. Alternatively, follow steps 1 through 3 from above and select Normal to locate your current location.
eTrex Touch Series
- Press
to access the app drawer
- Select Satellite
- Swipe up from the bottom of the screen, then touch
- Select Set Loc. On Map
Montana 600 Series
- Select Satellite
- Touch
- Touch
Montana 700 Series
- Touch
to reach the Main Menu
- Select Satellite
- Touch
- Select Satellite Setup
- Select Satellite System
- Select Demo Mode
- Touch
to return to the previous screen
- Touch
Oregon Series
Oregon 200, 300, 400, and 500 Series
- Select System
- Select GPS
- Select Demo Mode
- Touch
Oregon 600 Series
- Swipe up from the bottom of the screen to access the app drawer
- Select Satellite
- Touch
- Touch
Oregon 700 series
- Press
- If your user interface is set to Classic Mode, swipe up from the bottom of the screen to access the app drawer
- Select Satellite
- Touch
- Touch
Rino Series
Rino 600 series
- Select System
- Select GPS
- Select Demo Mode
- Touch
Rino 750 and Rino 755t
- If your user interface is set to Activity Mode, press
- Select Satellite
- Touch
- Touch
