Using Bluechart® Mobile to Send and Receive User Data with the GPSMAP® 4xxx, GPSMAP®5xxx, GPSMAP®6xxx, and GPSMAP®70xx series, GPSMAP® 72xx Series Chartplotters
BlueChart® Mobile is a marine trip planning program that can be used to plan waypoints, routes, and tracks. BlueChart Mobile can send this data to a compatible chartplotter, or receive user data that is already on a chartplotter.
To be able to transfer user data for the GPSMAP® 4xxx through GPSMAP®70xx, GPSMAP®72xx series units, a Marine Wi-Fi Adapter Kit will need to be purchased and installed.
After the adapter kit is installed and the BlueChart Mobile device has made a connection with the wi-fi adapter, follow these instructions:
To receive user data from the chartplotter to BlueChart Mobile:
  1. Press the Settings icon in BlueChart Mobile
  2. Press Garmin Marine Network
  3. Press Import
  4. Press Yes on the chartplotter when the question “Send data to a mobile device?” appears
  5. Press OK when the transfer / import is completed
To send user data from the BlueChart Mobile device to the chartplotter:
  3. Press Export
  4. Press Yes on the chartplotter when the question “Accept data from a mobile device?” appears
  5. Press OK when the transfer / export is completed
