GMI 10 or GMI 20 Displaying Total Fuel Flow Rate Instead of Each Engine's Individual Fuel Flow Rate
The GMI™ 10 display and GMI™ 20 display are capable of displaying the fuel flow rate for each engine. If only total fuel flow rate is shown, the GMI 10 or GMI 20 is not setup correctly.
To configure the GMI 10 or GMI 20 to display each engine's fuel flow rate, follow these instructions:
  1. With the GMI 10 or GMI 20 powered ON, press the Menu button
  2. Select Add/Remove Page
  3. Select Custom
  4. Select Custom Page
  5. Select the Page Layout number to match the number of engines on the boat
  6. Select the first option
  7. Select Engine
  8. Select the appropriate engine for that box
  9. Select Fuel Flow Rate
  10. Select Digital or Analog
  11. Select the next option from the custom page
  12. Repeat steps 7-11 as needed
Once the device is setup properly, it will represent each individual engine's fuel flow rate as opposed to the total fuel flow rate.
