Adding Ranges and Fixed Pins to the Xero X1i
If you did an auto calibration on your Xero® X1i Crossbow Scope your max range will automatically be set to 80 yards. To increase your max range you can add additional calibrated ranges.
How Add New Aim Points on a Xero X1i Crossbow Scope
  1. From Main Menu, select Profiles.
  2. Select your active Bolt Profile.
    Xero Profile
  3. Select AIM POINTS
  4. Choose an option:
     Xero pin selection
Adding Calibrated Ranges
  1. Scroll to and select Add Aim Point Xero X1
  2. Select CALIBRATED RANGE.
  3. Range target at desired distance for calibration.
  4. Make electronic adjustments by following on-screen prompts.
Adding Fixed Aim Points
Using fixed aim points can be helpful if a shot opportunity comes up quickly without enough time to range. Specific ranges for the fixed aim point stack can be customized using steps under How to Edit Aim Points (see related content below).
  2. Select FIXED AIM POINT.
  3. Enter RANGE.
  4. Select a color.
  5. Go back or repeat steps to add another aim point.
NOTE: Added "Fixed Pins" are based on previously calibrated ranges, thus do not require a validation shot and can be done at any time.
NOTE: Press the Range button at anytime to back out to the profile menu. Press it again to return to the ranging display.
If you need additional help see the related content below.
Related
