Top FAQs About the Index Sleep Monitor
Select a topic below to view details on frequently asked questions about the Index™ Sleep Monitor sleep band.
Can It Be Used for Broadcasting Heart Rate Data or Activity Tracking?
Does Sleep Data Captured by My Index Sleep Monitor Impact My Training Metrics?
How Do I Set Up My Index Sleep Monitor?
Follow the pairing instructions in your owner's manual if you are setting up the Index Sleep Monitor for the first time.
If you need to readd your Index Sleep Monitor, ensure it is no longer listed in the Garmin Connect™ app or your phone's Bluetooth® before trying to re-pair. For instructions, see Remove and Add a Device From the Garmin Connect App. Then grab your Index Sleep Monitor and place your finger on the heart rate sensor for 5 seconds and wait until the device boots up. It will flash white while it tries to connect to a phone. Rapidly tap on the module 10 times within 2 seconds. This should initiate the pairing mode and the device will flash purple until a new phone is paired.
What is the Best Way To Use This Device?
The Index Sleep Monitor will go idle after 5 minutes of non-use. Wake the monitor up by putting your finger on the heart rate sensor for 5 seconds. The LED light will flash white accompanied by a vibration as it is rebooting. When it is fully rebooted, the LED will flash purple briefly followed by a series of short vibrations. At this point, take off any other wearable Garmin® device and slide the Index Sleep Monitor up your arm in a comfortable position where the sensor will not get pinned against your arm. After waking, slide the monitor off your arm but be mindful not to cover the heart rate sensor or put it on a reflective surface. As long as your phone is nearby with the app running, your data will sync within a few minutes.
What if I Have Tattoos Where I Place the Sleep Band?
Tattoos (ink, pattern, saturation) can block the heart rate sensor's light causing inaccurate or missing readings. For best performance, wear the sensor on skin that is free of tattoos.
What if I Forget to Remove My Garmin Watch Before Bed?
If you wear both a Garmin watch and the sleep band to bed, the sleep data you see will have come from the Garmin watch rather than the Index Sleep Monitor.
How Does Sleep Tracking Work?
For detailed information about sleep tracking, see Sleep Tracking with the Index Sleep Monitor.
Can I Track Naps?
The Index Sleep Monitor does not record naps. The monitor should be used at or near the set sleep schedule for best results. For information on how to edit your sleep schedule, search "sleep schedule" in your owner's manual.
No, the Index Sleep Monitor cannot broadcast heart rate, record steps or activities. It is designed to use only while sleeping.
Yes, sleep data from the Index Sleep Monitor will be integrated into your training metrics to update recovery time and training readiness.
Can I Set an Alarm?
Yes, for more information search "alarms" in your owner's manual.
Does It Matter Which Way I Put The Armband On?
It does not matter which direction you put the armband on. The monitor just needs to be on the upper arm with the sensor squarely on the skin.
What Is the Material of the Band?
The band is composed of a mix of synthetic materials (70% nylon, 30% spandex) that have been specifically chosen for breathability, comfort and flexibility. The band also has plastic and woven fabric materials used to create the adjustment mechanism.
Can I Wash My Index Sleep Monitor?
The band can be washed but you must remove the module first. For instructions, search "washing" in your owner's manual.
How Do I Know When to Charge The Monitor?
The LED will flash red when the battery is critically low. You can also check the battery percentage in the Garmin Connect app or enable push notifications so you are alerted when the battery is low. The battery generally lasts 7 nights but vibration intensity and duration of sleep each night can impact the overall battery life you receive.
Checking the Battery Percentage
Open the Garmin Connect app.
Select More (bottom right).
Select Garmin Devices.
Select the Index Sleep Monitor.
Select Device Settings.
Select Battery Percentage.
Enabling Low Battery Push Notifications
Select Settings.
Select Notifications.
Select Push Notifications.
Swipe to Low Battery and toggle it on.
Select the back arrow to save the changes.
How Long Does Charging Take?
It can take 2 hours to fully charge the battery depending on the level of charge.
