Log in to the Garmin Explore™ website.
Navigate to the Map page.
Select Waypoints, Tracks, Routes, Activities, or Courses under Library.
Select M to toggle MapShare.
Select the checkbox for Library.
Select Save.
Library and Collection Data Not Seen in MapShare
The MapShare™ page is designed to display user information, such as waypoints, tracks, routes, activities, and courses so that approved users can view them.
NOTE: Date and time stamps will be displayed using the time zone your computer or mobile device is set to when viewing MapShare. If you are accessing your own account, make sure you do not have the Garmin Explore™ website map page and your MapShare page open at the same time as this may prevent tracks or other items from displaying correctly.
Library and Collections can be enabled or disabled to be viewed on the MapShare page, allowing control of what others can see. Steps for this can be found below. You can also set the visible Library and Collections from the Social page by clicking Filter MapShare Data.
Library
The Library contains all of your data sorted by type. Any data you create with a device, import from a file, or draw on the map will appear in your Library.
The interaction between the Library and MapShare page may be affected by what has been Checked or Unchecked:
Checked - Displays all waypoints, tracks, routes, activities, and courses lists in the Library.
Unchecked - No waypoints, tracks, routes, activities, or courses will appear from the Library.
Collections
Think of Collections like containers for your data. Data can be added to more than one collection and data in Collections will appear in the Library.
The interaction between Collections and MapShare page may be affected by what has been Checked or Unchecked:
Checked - Displays all waypoints, tracks, routes, activities, and courses in Library and any Collection that is enabled.
Unchecked - Waypoints, tracks, routes, activities, and courses in Library will not appear, but data in enabled collections will appear.
