What is the SonarChart Live Mapping Feature?
SonarChart™ Live allows you to create a high-definition bathymetry map that displays on your device in real-time while navigating. The new chart appears as an additional layer over either Nautical Chart or SonarChart using your plotter/sounder or mobile device. SonarChart Live is an excellent way to monitor the improvements your survey will bring to SonarChart because contours are instantly seen while you are collecting sonar logs.
Track with depth contours being created around it in red.
