How Adventurous Routing Works on a zumo Device
Adventurous Routing expands on Curvy Roads routing and allows you to set preference levels for curves, hills, and major highways.
To access Adventurous Routing in your device's navigation settings:
  1. Touch Settings
  2. Touch Navigation
  3. Touch Calculation Mode
  4. Touch Garmin Adventurous Routing
  5. Touch Save
Your device will now use this calculation mode.
To change Adventurous Route settings:
  1. Touch Garmin Adventurous Routing1
  2. Touch and drag each slider to your preference
The device will now use the chosen preferences in determining an adventurous route.
Adventurous Routing is available in the following regions:
  • North America
  • Europe
  • Australia/New Zealand
  • South Africa
  • South America
For information on the different zumo routing preferences and how they work, see Related Content.
1Garmin Adventurous Routing will be "grayed out" in the Navigation menu until it has been selected as the Calculation Mode using the first set of steps above.
Related
