Routes Created in BaseCamp™ Appear Different on an Outdoor Handheld
BaseCamp™ software can be used to create routes that can then be loaded to outdoor devices. If certain parameters are set differently on the device than in BaseCamp™, the route may recalculate using the device parameters.
To reduce changes in routes, confirm the following:
  • BaseCamp™ and device software are up to date:
  • Route is created in BaseCamp™ program using the same map that is loaded to the device.
  • Routing activity profile in BaseCamp™ matches that on the device. Update your device to insure all profiles are up to date. Some devices do not support profiles found in BaseCamp™.
  • Avoidances on device match avoidances set in BaseCamp™.
  • Set "Off Route Recalculation"  to "Prompted". To do this, complete the following steps:
    1. Select Setup
    2. Select Routing
    3. Select Off Route Recalculation
    4. Select Prompted
Utilizing the above suggestions will help reduce changes made to routes when loaded to the device.
