How to Activate an inReach Device on the Garmin Explore Website
Before you can use the messaging and SOS functions on an inReach® satellite communicator, you must create an account and activate a service plan for it.
IMPORTANT
Activating an inReach Device
For devices that work with the Garmin Messenger app, see - Pairing and Activation Instructions for Garmin Messenger App Compatible inReach Devices.
Only use the steps below for devices that are not compatible with the Garmin Messenger™ app. If you have an inReach device that was acquired second-hand, it may also need to be reset before proceeding with these steps. To reset the device, refer to your Owner's Manual.
IMPORTANT: These steps are for users that do not currently have any inReach subscription. If you have an existing inReach account and need to transfer service from your current inReach device to a new inReach device, you will need to follow the steps in Transferring Existing inReach Service to Another inReach Device.
  1. Go to explore.garmin.com and select Satellite Communicators.
    • If you already have a Garmin account, but do not have any inReach subscriptions, make sure you are signed out before continuing (select the profile image next to your email address in the top right of the page, then Sign Out).
    • If you have an inReach account but do not have an active inReach device:
      1. Select Sign In and log into your account.
      2. Select PLANS & DEVICES.
      3. Select Add inReach Device.
  2. Select the link to activate without using an app.
  3. Enter the inReach device's IMEI number and Authorization Code, then select Next.
    Select your device on the page if you need help finding your IMEI and Authorization Code.
    IMEI and Authorization Code Fields
  4. Select Create One, then enter your name, email, and a password and select Create Account.
    • NOTE: If you do not have any inReach subscriptions, but already have a Garmin account or have previously used other Garmin apps such as Garmin Connect™ or Garmin Explore™ you can select Sign In.
  5. Select the country/region for your billing address, then select NEXT.
  6. Select a specific plan.
  7. SOS step:
    • Read through benefits included with your subscription by Garmin Response, then select NEXT.
    • If desired, choose ADD for one of the Search and Rescue (SAR) insurance plans. This is not required. SAR insurance plans are available for purchase in the US, Canada, and US Territories (American Samoa, Guam, Northern Mariana Islands, Puerto Rico, US Virgin Islands). Once finished, select NEXT or SKIP.
  8. If desired, choose ADD for Outdoor Maps+. This is not required. Once finished, select NEXT or SKIP.
    NOTE: This option will not be presented when activating an Earthmate® app compatible device.
  9. Select the box to agree to automatic renewal, then select NEXT.
  10. Review the terms and conditions, then select ACCEPT & CONTINUE.
  11. Enter your billing information, then select NEXT.
  12. Enter your emergency information (or select the box for Same as Billing Info), then select NEXT.
    • Emergency Notes is a good place to add information of any known medical concerns. If you have additional coverage for medical evacuation or search and rescue, you can include that and how to get in contact with the company providing that service. Example:
      SOS Contact and Information for Medical Evacuation Coverage
  13. Add Emergency contacts information, then select NEXT.
  14. Review all entered information to confirm it is correct, then enter your payment information.
  15. Check the box to authorize use of this payment method for future account charges, then select COMPLETE ACTIVATION or CONFIRM PURCHASE.
  16. Take the inReach device outside with a clear view of the sky to complete the activation process.
Sync Your Device
After activating, you need to sync your device. For instructions, see -  Updating inReach Firmware and Syncing Account Changes with inReach Sync.
Registering Your inReach
Your inReach device is registered automatically during activation of service to the device.
Related
