The Module Display ELH (Error LIMP Home-Mode)
Unit does not have any connection with the network, check the NMEA2000 network.
-Check network power.
-Check NMEA2000 termination. The network shall have two terminators installed. To be certain you can power OFF the system and measure OHM between pin 4 and 5 (standard Micro C connector). A proper terminated network has 60 Ohm (two 120 Ohm terminator in parallell).
