Can a Single Radar Networked to Multiple Chartplotters Provide Different Ranges
Compatible Garmin chartplotters, connected to a Garmin radar, can display radar returns for areas from 1/8 of a mile up to a maximum of 72 nautical miles.* The user applies settings from the chartplotter to select the range of radar returns to show on the chartplotter screen.
If multiple chartplotters are connected to the radar simultaneously, each screen will show the same radar returns at the same range. Having two connected chartplotters display a different range from one radar is impossible. Changing the range on one screen will also cause all other connected screens to change range.
The following Garmin radars can show a Dual Range radar display when connected to GPSMAP® 7x2 chartplotters | GPSMAP® chartplotters | GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters |GPSMAP® 7x3 chartplotters | GPSMAP® 9x3 chartplotters | GPSMAP® 12x3 chartplotters | GPSMAP® 16x3 chartplotters | GPSMAP® 74xx chartplotters| GPSMAP® 76xx chartplotters | GPSMAP® 84xx chartplotters | GPSMAP® 84xx chartplotters | GPSMAP® 90xx chartplotters | GPSMAP® 92xx chartplotters:¹
GMR Fantom™ 4 open array | GMR Fantom™ 6 open array
GMR Fantom™ 18 dome | GMR Fantom™ 24 dome
GMR Fantom™ 254 open array | GMR Fantom™ 256 open array
GMR™ 18 xHD dome | GMR™ 24 xHD dome
GMR™ 404 xHD open array |GMR™ 604 xHD open array
GMR™ 406 xHD open array| GMR™ 606 xHD open array
GMR™ 424xHD2 open array | GMR™ 626 xHD2 open array
GMR™ 1204 xHD open array| GMR™ 1206 xHD open array
GMR™ 1224 xHD2 open array | GMR™ 1226 xHD2 open array
GMR™ 2524 xHD2 open array | GMR™ 2526 xHD2 open array
The Dual Range option shows a split-screen, with each side of the split-screen having a user-adjustable range. The screen's left side can show a range of three nautical miles or smaller, and the right side of the screen can show a range of 3 nautical miles or larger. All compatible chartplotters on the network will show the same dual ranges as the other network devices.
*The maximum radar range is dependent on which model of radar is being used. Refer to the Owner's Manual or Installation Instructions for your radar for your device's maximum distance capabilities.
1 legacy chartplotters GPSMAP® 4xxx chartplotters | GPSMAP® 5xxx chartplotters | GPSMAP® 6xxx chartplotters | GPSMAP® 70xx chartplotters | GPSMAP® 72xx chartplotters
