Errors on an Automotive Device when Plugged into a Vehicle Power Cable
The USB port on the device may not be properly recognizing the cable if the device shows an error when connected to the vehicle power cable.
Symptoms of this Include:
  • The device displays the error Attached power cable is not supported.
  • The device displays the error The connected power cable does not support traffic.
  • The device displays the error Low Battery.
  • The connection between the vehicle power cable and the device is loose.
  • The device shows an icon of a computer on the screen.
To Resolve this Issue:
  1. Update the software on the device.
    • Go to the Support Center and enter the product name or the serial number of your device.
    • Click Software in the panel on the left under the device name/picture for full instructions.
  2. Verify the cable being used is the vehicle power cable packaged with the device.
    • These will typically have the word GARMIN stamped on the plug and be labeled Car ChargerTA, or GTM on the back.
    • Do not plug the device into a USB port in the vehicle, as this could cause the above errors.
    • Third-party cables may not properly work with the device and could cause the error in question.
  3. Ensure the car charger is inserted into the correct port on the device completely and securely.
  4. Ensure the vehicle power cable and USB port on the mounting bracket or device are not damaged.
  5. Turn off the device instead of activating Standby/Sleep/Suspend mode to prevent battery loss.
    • To turn off the device, press and hold the Power button for several seconds and then press Off.
    • It will require several seconds to reboot a device after it has been fully turned off.
    • This will shut down the device and best preserve its battery charge.
Contact Product Support if the steps above fail to resolve the issue.
Garmin Express™ Software Connection Issue:
    • Arctic Cat G8 Display
    • Camper 780 & Traffic caravan and motorhome sat nav
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 795 caravan and motorhome sat nav
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • CamperCam 795 motorhome sat nav with built-in dash cam
    • CamperVan caravan and motorhome sat nav
    • dēzl™ 780LMT-S GPS navigator
    • dezl™ LGV500 and dēzl™ OTR500 GPS navigators
    • dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
    • dēzl™ LGV620 and dēzl™ OTR620 GPS navigators
    • dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
    • dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
    • dēzl™ LGV720 and dēzl™ OTR720 GPS navigators
    • dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera
    • dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera
    • dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
    • dēzl™ LGV820 and dēzl™ OTR820 GPS navigators
    • dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
    • dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin Catalyst™ Driving Performance Optimizer
    • Garmin Drive™ 53, Garmin Drive™ 53 & Traffic, and Garmin Drive™ 53 & Live Traffic GPS navigators
    • Garmin DriveCam™ 76 GPS navigator with camera
    • Garmin DriveSmart™ 55 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator
    • Garmin DriveSmart™ 65 Traveler's Edition GPS navigator
    • Garmin DriveSmart™ 66 GPS navigator
    • Garmin DriveSmart™ 71 GPS navigator
    • Garmin DriveSmart™ 76 GPS navigator
    • Garmin DriveSmart™ 86 GPS navigator
    • Kawasaki RIDGE 8" Tread Display
    • Overlander® GPS navigator
    • RV 780 & Traffic RV navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 795 RV navigator
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • RVcam 795 navigator with built-in dash cam
    • Tread®, Tread® - Base Edition, Tread® 2, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SxS Edition, Tread® XL - Baja Chase Edition, and Tread® XL - Baja Race Edition GPS navigators
    • zūmo® XT and zūmo® XT2 GPS navigators
