Using the Group Ride App on the zūmo XT
The Group Ride App on the zūmo® XT GPS navigator allows you to coordinate rides and communicate with nearby riders using preset text messages, live map locations, and voice communications.
Also, the zūmo® XT and zūmo® XT2 GPS navigators and any of the Tread® devices with a group ride radio would be able to join a group ride together.
NOTE: The Group Ride Radio Mount (Sold Separately) and a software update are required to use the Group Ride features.
Up to 20 riders can join a Group Ride.
Icons for other vehicles will be visible on the map screen as you ride.
Rider colors cannot be changed.
Group Ride leader is blue.
Other rider colors are randomly assigned.
Users should be close together when setting up a Group Ride.
New riders can be added by any nearby member of the group once a Group Ride has started.
Group members will be alerted a new rider has joined once they are in radio range of the new rider.
Range performance varies based on terrain and other line-of-sight limitations.
Each group ride participant will only know positions of others within their radio range.
Depending on terrain (hills, trees, etc.) each rider may only know the position of some of the riders within the group.
The zūmo XT must be mounted with the antenna properly installed before starting a Group Ride.
The default map view for Groups Rides is "Auto Zoom to Group".
The map will automatically zoom in and out based on the location of active riders.
See the Owner's Manual for instructions to adjust the map view for Group Rides.
See the Detailed Video Below for Instructions to Install the Group Ride Radio Mount on your zūmo XT.
See the owner's manual for instructions to set up a Group Ride.
