Upgrading Vector S/2S to a Dual-Sensor System
Vector S/2S are single-sensor power meter systems that measure power from the left pedal to provide an approximate total power value. With Vector S/2S you have the option to upgrade to a dual-sensor system that will measure power from both pedals and provide additional metrics.
IMPORTANT: The Vector 2 system was discontinued in 2017 and may result in the inability to find available upgrade pedals to purchase.
To Upgrade Vector S/2S to a Dual-Sensing System
NOTE: Before upgrading your Vector S/2S system you will need to ensure that your crank arm and chain clearance are compatible by referring to your owner's manual.
1. Purchase Vector 2S Upgrade Pedal (010-12338-00) and ensure proper size for your crankarm1.
Vector 2 right sensing pedal
2. Remove existing non-sensing right pedal.
3. Install2 right Vector 2 Upgrade Pedal with new pedal pod.
4. Pair the Vector 2 pedals with Edge or compatible Forerunner2.
5. Follow on-screen calibration instructions.
6. Check for software updates.
Having Trouble?
If the above steps do not successfully upgrade the Vector S/2S to a dual-sensor system Vector Updater can also be used:
  1. Open Vector Updater.
  2. Follow the on-screen prompts until Vector Updater says Pedal Found.
  3. Click Pair Pedals and follow the on-screen prompts.
Vector Updater window
Once upgraded, Vector will provide left/right balance, increased power accuracy, and cycling dynamics in addition to Vector S/S2 metrics.
1 Kits are available for Standard thickness and Large thickness crank arms.
2 For instructions on installation and pairing your sensors with your device, refer to your owner's manual.
