Unit Converter on the nüvi® 300 and nüvi® 600 series
To use the Unit Converter, follow the steps below:
- Turn the device on
- Touch Travel Kit
- Touch Measurement Converter
- Touch the Conversion button or the button that indicates which type of measurement is being converted (e.g., Area, Distance, Speed, etc...)
- Touch the desired item for conversion, and then touch OK
- Touch a blue box that contains a unit of measurement (e.g., millimeters, Celsius, grams, etc...)
- Select the desired unit of measurement from the list and touch OK
- Repeat steps 7 and 8 to change the second unit being converted
- Touch the box that contains a number (or value) for one of the units of measurement
- Enter the value to be converted
- Touch Done
The converted value will be displayed. Repeat these steps as needed.
