What are Track, Train, and Control Codes and Why Would I Use Them?
The Track, Train, and Control Codes are intended to be a virtual PIN code for you to share with others so that they can add your dogs into their Dog List to track, train, and control them. This PIN code prevents unwanted hunters from linking up with your dogs.
The following are step-by-step guides to view and use the Share Codes for the Astro® 430, Astro 900, Alpha® 100, Alpha 200, Alpha 200 Plus, Alpha 300 dog tracking handhelds, and the Alpha XL navigator.
NOTE: The appropriate collar(s) should be turned on and nearby when setting up training commands.
Alpha 100, Astro 430, and Astro 900 Handhelds
The Track Code is a 5-digit PIN number so other handhelds can share and track your dog.
The Train Code is a 5-digit PIN number that allows other handhelds to track and control (correction).
Alpha 100 and Astro 430 handhelds can share and pair to each other's dogs; Astro 900 handhelds can only share and pair to other Astro 900 systems due to a different radio frequency used.
Viewing Codes on the Alpha 100 Handheld
Go to Dog List.
Select the dog you want to view.
Choose Show Info.
Viewing Codes on the Astro 430 and Astro 900 Handhelds
Press Dog.
Using the arrow keys, highlight the dog you want to share and press ENTER.
Using the arrow keys, highlight Show Info and press ENTER.
NOTE: With the Alpha, you cannot track a dog just by knowing the ID number like the older Astro model handhelds (Astro 220 or Astro 320). On the Alpha handheld, you must have either the Track code (track on handheld only) or Train code (track and train on handheld) to see the dog on a different handheld.
Adding a Dog to an Alpha 100 Handheld Using a Share Code
Go to Dog List.
Touch Add Dog
When asked if you are near the collar, choose No.
When asked if you have the track or train code, choose Yes.
Enter the code and select the checkmark in the bottom right-hand corner.
The dog will now be added to your Alpha 100 handheld.
Adding a Dog to an Astro 430 or Astro 900 Handheld Using a Share Code
Press Dog.
Using the arrow keys, highlight Add Dog then press ENTER.
When asked if you know the track and control codes, choose Yes.
Enter the track or control code for the collar and select Done.
The dog will now be added to your Astro series handheld.
The Track Code is a 6-character PIN so other handhelds can share and track your dog.
The Control Code is a 6-character PIN that allows other handhelds to track, train, and control settings.
Viewing Codes on the Alpha 200, Alpha 200 Plus, or Alpha 300 Handheld
Go to Dog List.
Adding a Dog to an Alpha 200, Alpha 200i, Alpha 200 Plus, Alpha 300, or Alpha 300i Handheld With a 6-Character Share Code
Go to Dog List.
Touch Add Dog.
Touch Enter Track or Control Code.
The dog will now be added to your Alpha 200 or Alpha 300 handheld's device list.
Adding a Dog Tracked by an Alpha 100 to an Alpha 200, Alpha 200i, Alpha 200 Plus, Alpha 300, or Alpha 300i Handheld With a 5-Digit Share Code
Go to Dog List.
Touch Add Dog.
Touch Enter Track or Train Code.
Enter the 5-digit code and select the checkmark in the bottom right-hand corner.
Obtaining a 5-Digit Legacy Share Code From an Alpha 200, Alpha 200i, Alpha 200 Plus, Alpha 300, or Alpha 300i Handheld
The Alpha 200i and Alpha 300i handhelds can also share a 5-digit Legacy Code to an other handheld.
Tap the Dog List.
Select the Dog you wish to view.
Select
Select Legacy Share Codes.
Alpha XL Navigator
Viewing Codes on the Alpha XL Navigator
Go to the Pro View or Dog List.
Adding a Dog to an Alpha XL Navigator With a 5 or 6-Character Share Code
From the Main Menu select the Dog List shortcut.
Select the + symbol to add a dog.
Select Enter Track or Control Code.
The dog will now be added to your navigator's dog list.
Obtaining a 5-Digit Legacy Share Code From an Alpha XL Navigator
The Alpha XL navigator can also share a 5-digit Legacy Code to an other dog tracking device.
Tap the Dog List.
Select
How to Change Your Track, Train and Control Codes
There are two ways you can change the codes on your collar. Changing the codes will stop the collar from being shared on anyone else's device, even if it was added manually.
