NMEA 0183 Sentences Available on Compatible Garmin Handhelds
Some Garmin handhelds1 have the ability to output NMEA 0183 data for the purposes of interfacing with various pieces of marine equipment. Below is a list of sentences that are output2 by these devices. The Serial Data/Power Cable is required to connect a handheld to the marine equipment.
GPRMC
GPRMB
GPGGA
GPGLL
GPBOD
GPBWC
GPVTG
GPXTE
PGRME
PGRMZ
PGRMM
HCHDG
The autopilot mode on the device interface enables only the following sentences:
GPRMC
GPRMB
GPAPB
GPXTE
Under the NMEA sentences you can toggle three groups on and off.
Status: GPGSA AND GPGSV
Waypoints / Route: GPRTE AND GPWPL
GRMN Proprietary: PGRME, PGRMM AND PGRMZ
The Heading, Deviation and Variation (HDG) sentence contains the compass heading. The Altitude (PGRMZ) sentence contains the barometric altitude.
For further information regarding the interface options, refer to the owner's manual.
1 Compatible series: GPS 73, GPSMAP 62, GPSMAP 64, GPSMAP 78, Montana 600 series devices, and Oregon series devices (see note on the GPSMAP 66, GPSMAP 79, & GPSMAP 86 series)
2Some NMEA sentences may require a software update. See related content for assistance with updating the device.
NOTE: The GPSMAP 66 series, GPSMAP 79 series, and the GPSMAP 86 series can output the above listed sentences through a USB port to a computer; it does not connect directly to onboard marine equipment. |
