Pairing Approach CT10 Sensors With the MARQ Golfer
The Approach CT10 sensors can be paired with the MARQ Golfer to allow you to track shots for any club and automatically assign clubs to each shot. Follow the steps below to be guided through the pairing process.
Pairing the Sensors
- Attach all sensors to your clubs
NOTE: For instructions attaching the sensors, see your Owner's Manual. - Take a club out of your golf bag. Keep all other clubs in your golf bag while pairing
TIP: You should complete the pairing process in a well lit room. - With the grip pointed up, bring the club within 1 m (3 ft.) of your device
- On the watch hold the MENU button
- Select Sensors & Accessories
- Select Club Sensors
- Select Add New
- The watch will search for the sensor and a message will appear when the sensor is detected
- Follow the on-screen instructions to complete the pairing and a message will appear when the sensor is assigned
- Return the club to your golf bag
- Repeat steps for each sensor you want to pair
The Approach CT10 sensors will automatically pair back to the watch when you are using them for golfing.
